few questions about cylinder heads. one is haw much more would it help to put a set of aftermarket heads on a stock bottom end ls1 that is running a turbo? i know it will allow to run a little more boost but would it be worth it over a set of 317s. the second is will those same heads work well on a 370? and what brand heads are a good bang for the buck like the TFS fast as cast or something along them line
