Hilborn, E85 and NOS....
5.2K views 23 replies 9 participants last post by  roadkill trucking
Running a 417 sbc with Hilborn injection. Engine is an old circle track thing and works really well for us. Added 200hp of NOS with a Fogger system and NOTHING happened??? Running the old Pontiac heads, fully ported with 2.10 intakes etc.
AFR reading around 8 over the line.
Any input from E85 and NOS users???
Roadkill Trucking/C-10 Racing:confused:
#6 ·
Engine is an old track motor from 1990. Built by Prototype Racing = Ron Neal.
Callies crank, titanium rods and most of the bells and whistles. Pontiac heads ported by H.V.H. with 240cc runners and 2.10 intakes. The cam is still the track version with not much happening over 7000. A new roller is in process...
Running an MSD distributor and MSD 6 Digital with high voltage coil.
Mechanical Hilborn with 12" stacks. It runs O.K. until we turn the NOS on and sounded like loosing cylinders on the last run Saturday. AFR reading approx. 8 across the line. Is there too much E85 and NOS so the plugs can't handle it?
#7 ·
If your “loosing cylinders”, look at the whole ignition & fuel system, and make sure everything is right. Maybe get a new coil before pulling your hair out too much.
Your tune doesn’t look bad.
If your AFR is reading 8, I don’t think it’s flooding the motor out like you state, but what do the plugs look like?
If the plugs look ok (safe), add a little more timing in, and see if it picks up.
I pulled 10* at first on a 150 shot. And the car didn’t go for shit, went from a 12.08 on motor to a 11.80. I changed it to pull 5*, and it picked up almost a second (in sig).
My car does just what your describing here when the bottle is empty… runs like it’s on motor. Put the bottle on a scale, and make sure it is at least 19-20#, min. you can have 1000 psi on a half full bottle (ask me how I know:rolleyes:)
I am not sure about champion plugs. But I’ve always had good luck contacting NGK directly for spark plug recommendations. They are usually within a heat range for whatever we’re doing. You can contact them here: http://www.ngksparkplugs.com/About_nGK/formtech.asp
Close up the plug gap on the bottle, too. I run .040 on motor and .025 on spray.
Is this a converter or clutch car? If you rule out the ignition, it may be simply pushing right through the converter.
good luck with it... my little 350 was a dirt track motor in another life, so I know yours will run like a scalded dog;)
#8 ·
Thanks for the input Big Ricky3. The coil should be O.K. as it's all new MSD stuff.
Plugs are way safe and wet.. after a NOS run. The E stuff burns so slow that I guess with 8* it's burning in the primary pipes instead of the heads.
I'm thinking of changing places with the jets just to check what happens to the AFR reading. Will try with 6* retard and 39* ground setting.
Bottle was definitely full during the 2 runs we made but we kept the pressure at recommended level. Just for once being careful...and following instructions...and Nothing happened..so much for that!
The C61Cx plugs we use are recommended for the heads but probably for high octane racefuel. I've also always used NGK with good results in the other engines we've been running.
We're running a PG with 1.80 first. The converter is a TCI and might be a little too weak for the truck. Total weight 1317Kgs with driver, 10.21 212km/h n/a
Will get back to you after the next race!
Thank You
#10 ·
If the plugs are wet, your way fat. Is it like that on motor, too? Way fat tunes kill power.
There are 2 schools of thought with e85, fat with a lot of timing, or lean with "gas" timing. I do the later. Don't try to mix, or you'll get in trouble.
Id pull a little fuel out, until the plugs dry out, then add a little timing. That hilborn setup should actualy be jetted more like its on gas than meth.
#14 ·
Hi Uncle Paul,
No, we're running regular pump E85 so we have no control of the variations. Different track, different gasstation...
No missfiring, just no balls...and loosing fire on some cylinders close to the finishline.
We have actually richened the highend as we started out around 9,5 with plugs still looking safe.
#19 · (Edited)
If its missing your AFRs might not be correct. Misfires will cause a wideband to read leaner than what it really is. If you say plugs are wet after trying to spray it than I would say its most likely going super fat with misfires.
You might not be getting nitrous. You might have already check but im just throwing it out there. Ethanol aint like gas. It will drive thru super rich conditions.
My personal junk. N/A runs .80 lambda. On 160 shot runs .75 lambda with 5 deg. pulled. Maybe a tad rich but runs fucking good.
#23 ·
if your a wet system you need a seperate electric pump . pulling fuel off will lower psi to nozzles .
the mech. pump was for methanol than it may be too big for e85 .you need to flow ck .the pump and system before you start messing with n2o.
i have run the electric by pass on motor and then added the right dry/n2o to match the bypass off the timing was controlled by normally closed relay contact . when system is armed
#24 ·
O.K. Been a couple of hectic days checking everything out and following different thoughts: All systems work as they are supposed to, full bottle, ignition O.K. Fuel pressure O.K. to NOS system. Everything checked but not been able to make a run yet. Must be overfeeding... Will change plugs and change the cam to a CompCam made for this engine... Have a feeling that this short track cam is not doing us any good right now.
The Lambda reading is another Q that we'll have to straighten out. We have absolutely no back or missfiring and the equipment has been checked on a gas car and then switched over to E85.
The work continues;o) Thanks for the input so far guys!!
