Building a 598 (4.6 bore x 4.5" stroke) as a play motor for our flat and looking for suggestions on heads. I've built a lot of race motors, but this is my first pump gas deal. This isn't an all out motor, really looking for good reliabilty but would like to get at least 800 HP @ 6800 RPM or so. Will be a single dominator, smallish solid roller (265-270 @ .050"), around 10.5:1 CR and has to run on 91 octane.
For those not familiar with boats, a flat acts a lot like a car with a race converter in it. It won't see hardly any time below 3k, and when you smack the throttle, the prop burns to around 4k to 5k almost instantly (we can vary this just like changing stall RPM)...
Done a couple searches and it seems the consensus is mixed. Some say go for a small head, 320 ccs or less to make it snappy. Others are using bigger heads, in the 340+ cc's. Over the years, I've had good luck with Dart, Brodix and AFR open to other choices. Kinda leaning towards the Dart 335 CNC's.
Appreciate any help.
Thanks....
Thanks....
