Go Back   Yellow Bullet Forums > Technical Section > Turbo Charged - Blitzkrieg Motorsports
Old 09-15-2009, 01:46 PM   #1
jon volk
Default 'glide...what gear on the chassis dyno?
Turbo guys running a glide. Do you usually dyno it 1st or 2nd? Seems like 2nd would make for some pretty high wheel speed. Im used to using 3rd gear in a manual tranny which seems to be around the same as the first gear in a glide generally speaking.
What do you typically do?
http://www.666fabrication.com
turbo 23* sbc '65 Mustang
jon volk is offline   Reply With Quote
Old 09-15-2009, 02:04 PM   #2
wazslow
Launchin
Default Re: 'glide...what gear on the chassis dyno?
2nd gear. You need to be 1:1 for any kind of accurate results. Why are you worried about wheel speed?
1989 Mustang Notch
434 SBF, PT101, CSU Carb, Glide
8.17low boost 172 best mph... @ 3460lbs on 315 MT radials first pass out in 2 years
wazslow is online now   Reply With Quote
Old 09-15-2009, 02:06 PM   #3
jon volk
Im not worried about it, just compared to usually doing alot of cars in 3rd I didnt know if it would make a diff.
Old 09-15-2009, 04:46 PM   #4
DLW
Spooled up
DLW's Avatar
Should be done 1:1 which is second gear in a PG and 3rd in a THxxx, 4th gear in a manual 6 speed etc...
DLW is offline   Reply With Quote
Old 09-15-2009, 05:55 PM   #5
Stangler
Spooled up
High gear (2nd) for me, I would think it would blow the tires off if I did it in 1st....
Nate
88' Mustang coupe
New combo-goal 8.99 @ 150
So far-
1.46 60ft- 6.12 @ 115.9
235/60/15- 8.5" Mickey Thomposn DR's
Stangler is offline   Reply With Quote
Old 09-15-2009, 08:34 PM   #6
njc.corp
njc.corp's Avatar
Cool Re: 'glide...what gear on the chassis dyno?
Quote:
Nate
would blow tires for sure
njc.corp is offline   Reply With Quote
Old 09-16-2009, 02:37 AM   #7
twinturbogt
Offending Ballwashers
twinturbogt's Avatar
I always thought you put it in "R" for race.
Special thanks go out to Proline Race Engines , Dan Saitz , Joe Oplawski , Steve Petty , Grant McCrary , MBE , Visa Platinum , and most of all my Wife .
Jeff Paynter
Stupidity cost money . How dumb can you afford to be ?
twinturbogt is offline   Reply With Quote
Old 09-16-2009, 02:38 AM   #8
twinturbogt
I always thought you were supposed to put in "R" for RACE.
Jeff Paynter
Old 09-16-2009, 06:46 AM   #9
jon volk
Second it is. Thanks.
Old 09-16-2009, 01:04 PM   #10
wazslow
Launchin
Here is my video in second gear. Doesnt take long when it makes 1200+rwhp on a mustang dyno LOL
Probably should have had the antiroll bar connected!!
http://videos.streetfire.net/video/1...g-a_680298.htm
1989 Mustang Notch
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
