Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 05-14-2009, 12:47 AM   #16
colo cracker
eats paint chips
colo cracker's Avatar
Default Re: whats the biggest single system you have used?
wow .063 to get a 3300lb ride in the sevens? I guess when people ask what a big tuneup is, it depends on what your motor and race program is.
Also powered by PKRE
colo cracker is offline   Reply With Quote
Old 05-14-2009, 12:56 AM   #17
teamguss716
Spooled up
teamguss716's Avatar
Quote:
Originally Posted by onefast68 View Post
now thats a promod tuneup.LOL.
thanks for the reply.
im pretty sure if i had that same combo now i could get it to live but at that time i was pretty new at running multiple stages. looking back on it now what was killing pistons was we had each system a lil on the rich side thinking we were being safe lol. it was fine on 2 but 3 tad rich tune ups togather = way rich = crushed ringlands
Jeremy McElrath www.teamguss.com
teamguss716 is offline   Reply With Quote
Old 05-14-2009, 01:00 AM   #18
colo cracker
eats paint chips
Quote:
i wouldnt be too hard on your self, thats a tough set up for anyone.
Old 05-14-2009, 01:10 AM   #19
onefast68
onefast68's Avatar
i run 6pill spreads around 5psi in both my foggers right now which i have never done before this year and i am running less timing than i ever have and the motor is living longer for sure.after my grudge race i plan to add a 3rd fogger but not as big of a tune as you did..maybe a 30 or 32pill in all 3 kits .hoping for some 4.90's on 3 kits.
68 camaro............................................ ........85 camaro street car
big duke 632 with 2 kits ..................................598 with 360 heads w 1 kit
4.98 at 144.7 ...............................................8.9 5 at 154
onefast68 is offline   Reply With Quote
Old 05-14-2009, 01:22 AM   #20
teamguss716
Spooled up
3 kits with 32's sound like a good and safe tune
Old 05-14-2009, 03:21 AM   #21
Monte Smith
The nitrous guy
Pullin gears
Quote:
Well, when you have a used up 525, conventional headed motor, with not the best heads and your class is limited to one system, you do what you have to do to run the number. 2800 lb/hr of nitrous is 2800lb, does not matter if it is 1, 2 or 3 kits. You would not think much if it had a couple .036 tunes in it, but this is basically the same difference, as far as the amount of nitrous goes. The guy that just said he had a .040 a .038 and a .030, that is about 4000 lb/hr of nitrous. Hell, just the first 2 are about 3000 lb/hr. That does not make my .063 tune seem big at all.
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
gtxmonte@msn.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 05-14-2009, 07:31 AM   #22
10.5
Launchin
10.5's Avatar
Quote:
Just out of curiosity, what is the jet spread/fuel pressure on that 63 tune???
10.5 is offline   Reply With Quote
Old 05-14-2009, 07:57 AM   #23
excelerater
excelerater's Avatar
im curious whats easier/faster
one mega sized kit w Prog or 2/3 small dual kits.....
excelerater is offline   Reply With Quote
Old 05-14-2009, 08:56 AM   #24
onefast68
onefast68's Avatar
was it single carb or tunnel ram?
Old 05-14-2009, 09:09 AM   #25
teamguss716
Spooled up
it was a single carb 1050, supervictor intake with two foggers on top and a under the intake fogger similar to the one steve johnson done for richie stine.
Old 05-14-2009, 09:19 AM   #26
onefast68
onefast68's Avatar
thanks,i plan to add the 3rd under the intake like that real soon...i bet i will have to get a neal chance converter to hold the power of 3 stages..your car worked extremely well to hold the big tunes you ran on 28's..did you have progressives?
Old 05-14-2009, 09:19 AM   #27
Big Squeeze
Spooled up
Big Squeeze's Avatar
Quote:
I've seen Monte post this before........It's 63N 36F at 7PSI...........
Pump gas and hydraulic cams are for minivans......
www.NITROUSCLASS.COM
Big Squeeze is offline   Reply With Quote
Old 05-14-2009, 09:33 AM   #28
teamguss716
Spooled up
yes, at the time we had 2 edelbrock progressives in kits 1 and 2, a neal chance converter is good and thats what we are running now ( because we got an excellent deal on it ) but when we were on NOS we had a cameron converter, if i remember right it was like $900, we even used this same converter when we put the 665 big duke motor in the car and it worked fine. we ran the same conv. for 3 years with no issues
Old 05-14-2009, 10:10 AM   #29
cutlass406
Member
Pullin gears
cutlass406's Avatar
Quote:
Originally Posted by Glen_Jones View Post
42's on a small block. Swapped to the 42Nitrous jet fogger setup from about 250 on a plate at around 2960#----5.12@140.---No progressive, Just timing.
You could tell pretty well when the big kit came on.
Glen
kind of like this kit on this car????? http://videos.streetfire.net/video/S...aro_169987.htm
Heads up.. it's the only way! http://kingsofstreet.net chris carter
cutlass406 is offline   Reply With Quote
Old 05-14-2009, 11:28 AM   #30
mikeyfrombc
mikeyfrombc's Avatar
Quote:
don,t know about the nitrous kit , but from the sound of the vid he,s got one high reving comp style motor with a stick behind it as well
Demon Precision Products
Precision Machining and Fabrication
mikeyfrombc is offline   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
