Go Back   Yellow Bullet Forums > Technical Section > Rearends - Driveline Solutions
Old 04-08-2009, 10:46 AM   #16
feetfirst
Member
Pullin gears
feetfirst's Avatar
Default Re: anyone broke a moser axle?
Quote:
Originally Posted by Scottyk View Post
In their defense there is alot more mosier axles out there than any other brand I would assume so its only natural that more of those would fail.
Strange fails as well..........there is a reason these parts fail, and odds are its "not" the axle's fault........but a suspension or housing flexing/alignment problem
Where 10" is more than a handful.......
feetfirst is offline   Reply With Quote
Old 04-08-2009, 02:56 PM   #17
dougd
Pre-Staged
dougd's Avatar
Hi: This looks like a bent or flexing housing with a mini spool.The mini spool rotates on the center pin and works the axle back and fourth until it breaks it like your photo shows.This may have been the result of a pin breaking first as it did.Mini spools are for circle track use only.thanks doug
Doug @ Quick Performance http://www.quickperformance.com
dougd is offline   Reply With Quote
Old 04-09-2009, 06:09 PM   #18
jester
Someone asked the same question on another fourm, they all responded the same. One included a video of moser axel breaking after the eliminators.
http://videos.streetfire.net/video/WAZSLOW_45260.htm
jester is offline   Reply With Quote
Old 04-09-2009, 06:50 PM   #19
quick331coupe
Launchin
quick331coupe's Avatar
I had a Moser axel break on the outside of the c clip eliminator. Luckily the tire wedged itself up in the fenderwell and it happended maybe 30 feet out. When I called them to find out about the warranty I told them it was on a drag radial car and they hung up on me. Never sold or used a Moser axle since then and that was 4 years ago.
quick331coupe is offline   Reply With Quote
Old 04-09-2009, 07:17 PM   #20
Trace Meyer
Trace Meyer's Avatar
This was compliments of Moser a couple of years ago. This was on the sixth pass on a new set.
Trace Meyer
NMRA Drag Radial
8.12 @ 171 on BFGs
8.01 @ 177 on M/Ts F1R
thanks to...
Team Z Motorsports, Procharger, Mike Curcio Race Products
Camshaft Innovations , Ultimate Converter Concepts
Doyle Racing & Custom Machining
Aluminum Tubing sold here-> 517-403-1914
Felpro Performance Gaskets
Trace Meyer is offline   Reply With Quote
Old 04-09-2009, 09:35 PM   #21
Manic Machinist
Member
Pullin gears
Manic Machinist's Avatar
Has anybody broke a 40 spline, gun drilled Moser axle?
Manic Machinist is offline   Reply With Quote
Old 04-11-2009, 03:14 AM   #22
Bruce Sneed
Member
Pullin gears
Bruce Sneed's Avatar
I would have never thought it was going to break without using a trans break. This is the pass before it broke.
http://www.youtube.com/watch?v=uQBXTfxyajY
Bruce Sneed is offline   Reply With Quote
Old 04-11-2009, 09:08 AM   #23
another69camaro
another69camaro's Avatar
this is making me nervous.my car has 35 spline mosers they came with the roller.3150lbs just went 8.06 170mph with a small hit and plan on spraying it a little harder.i think that has to be the week link need to go 40 spline strange or m/w.anybody going real fast with 35 spline mosers????.
another69camaro is offline   Reply With Quote
Old 04-11-2009, 09:26 AM   #24
Trace Meyer
Quote:
If your axles are made for 9" bearings and NOT c-clip eliminators you should be fine.
Trace Meyer
NMRA Drag Radial
8.12 @ 171 on BFGs
thanks to...
Old 04-11-2009, 09:43 AM   #25
another69camaro
yes it is a 9 inch ford w/fab housing.the axles are probably over 10 years old.
Old 04-11-2009, 10:00 AM   #26
excelerater
excelerater's Avatar
the 35 spline axles are no larger than the smaller models....I have gun drilled 40 mosers and they look way fatter
However Moser does offer warrentys.......Id send them back and ask for new ones,if they do not cooroperate buy some Strange 40s
excelerater is offline   Reply With Quote
Old 04-11-2009, 11:53 AM   #27
Supershafts
Launchin
Supershafts's Avatar
Quote:
Originally Posted by PONYEATER View Post
I have seen everyone's stuff break being in the drivetrain industry for a number of years. Rearends are the last thing upgraded in any drag car. Most guys don't think twice about upgrading from a 540 to a 598 or bigger
I agree.....If a 750" motor was ready to go right now and for $15k to $20k I would be seeing it all over again
The motor will get WHATEVER it needs, the trans will get about 24% of a after thought, with the rear getting 9 to 13% of a after thought (not the gear ratio, just the parts needed) and much haggling/bitching about price....while actually the driveshaft gets no thought until it breaks, wrecks the trans and rear/possibly exhaust and then even after living that experience, haggle/bitch some more about the price, never listen to any advice given....
Upgrading though, i have watched guys throw stupid money on some aftermarket f.i. system at $4500 + and do nothing anywhere else.. meanwhile they could have gotten more hp from a lighter shaft, better trans, rear done with different bearings, microed gears or other stuff for much less then the dopey bolt on parts...
Lol and then they ask how so and so's car breaks records... he didn't buy the $4500 f.i. sys and the $1400 lap top, he bought a $475 demon and tuned it for a day and a half... and he uses cer bearings with micro gears...while you banked on the miracle hp bolt on...
I see it everyday...
Also i don't care what you are using as for the BEST parts.... IF you keep running the car with tire shake and hop or a bent housing, bad wheel, diff sized tires, you'll break whatever you put in it.... fix it or get off the pedal when it happens...
This is the hardest thing to explain to the 4x crowd, they think oh we'll fix it we'll put a eaton ds-461-p (big 45,000 truck rear)........right that's the answer, see how much that ds461 likes to be bounced and loaded/unloaded
(running moser in my own vehicles for longer then i want to remember)
LIMA , www.LIMOTORSPORTS.ORG , Fighting to bring back motorsports on long island. We Race! We Vote!
]= www.Supershafts.com =[
Supershafts is offline   Reply With Quote
Old 04-12-2009, 04:04 PM   #28
PONYEATER
Faster then Thor
PONYEATER's Avatar
Well said...
Arron
PONYEATER is offline   Reply With Quote
Old 04-12-2009, 09:55 PM   #29
KylePBZ
KylePBZ's Avatar
WERD!
KylePBZ is offline   Reply With Quote
Old 04-13-2009, 06:33 AM   #30
dover1320
Launchin
dover1320's Avatar
Moser has a 10 year warranty. I broke my 33 spline after 9 yrs and 6 months. They replaced them with 35 spline. I had up graded everything through out the years except the axles. I agree, " tire shake is a bitch"
dover1320 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
