Go Back   Yellow Bullet Forums > Racing Organizations > Windsor Shootout
Windsor Shootout Windsor shootout 3 August 22,23 & 24 2008 St Thomas Dragway
Old 11-16-2009, 07:24 PM   #31
Shawn D
Shawn D's Avatar
Default Re: 8 second pontiac
Originally Posted by HS400 View Post
Any pics of this Poncho??
Here is a pic from last year at Milan
http://i775.photobucket.com/albums/y...t/tempest5.jpg
Shawn D is online now   Reply With Quote
Old 11-16-2009, 09:55 PM   #32
clutch assisted
What kind of trans are you rowin' in the car?
clutch assisted is offline   Reply With Quote
Old 11-17-2009, 02:20 AM   #33
WDCreech
WDCreech's Avatar
Originally Posted by Shawn D View Post
Thanks again guys.
Good to here from you Matt, not sure how many races I'll make but I'd like to get to a couple.
The Engine is a IA cast iron block, wideport E heads, as cast wenzler gutsram with two 4150 Holley's. 3.75 Stroke x 4.310 bore. And of course being a Pontiac engine I try not to rev it over 6500RPM !!!!!!
Shawn, that is one awsome car. As far as reving over 6500, if you've got good rods, and light pistons, you need not worry about it. especially with a 3.75 stroke. I'm running a 5" stroke, MGP aluminum rods, and JE pistons, and go through the traps at 81-8300. i remember my first 8 second pass in the 8.90s. Then the 840s, and now 8.20s. It's NEVER fast enough.
Bill
64 tube chassis GTO, 606" Indian Adventures tall deck
8.2550@164.17-1/4
1.1981-60'
3.4170-330'
5.2920@132.01-660'
OR
8.942 @ 149.96-1/4 w/474" Indian Adventures standard deck
Real INDIANS don't wear bowties
WDCreech is offline   Reply With Quote
Old 11-17-2009, 06:23 PM   #34
mufflerguy
mufflerguy's Avatar
I'm pretty sure Shawn has a little sarcasm dripping from that comment. 6500 would be closer to his launch RPM.
Rob Wade $20.00 actually!
mufflerguy is offline   Reply With Quote
Old 11-17-2009, 06:50 PM   #35
Fast455
Fast455's Avatar
That car is SOOOOO badass. Real pontiac power only makes it that much cooler. Good job Shawn.
Fast455 is offline   Reply With Quote
Old 11-17-2009, 11:31 PM   #36
Shawn D
Shawn D's Avatar
Thanks.
I ran a Jerico Clutch assisted 4 speed for the first two years after finishing the car, then put a Liberty 5 speed in it this summer.
Yeh I might be bending the truth a little bit on the 6500 RPM part !!!!
Old 11-18-2009, 10:20 PM   #37
clutch assisted
Thanks.
cool. I run a G-Force G101 clutch assisted 4 speed in a real olds powered 70 cutlass. those Liberty 5 speeds can handle some serious power, no?
Old Yesterday, 02:31 PM   #38
wood338P
wood338P's Avatar
thats a bitchin car shawn!!!
wood338P is online now   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
YellowBullet.com
